Discussion topic: Flickering UHD Sky channels
Message posted on 05 Mar 2023 07:17 PM
The TV screen flashes or flickers every now and then only when watching Sky UHD channels - very annoying.
There is clearly.a problem with the Sky box, everything else is set up correctly and works with other UHD sources well.
I have read discussion of this problem before, but I have not seen any solutions other than replacing the Q2TB box. Is there a less drastic solution that anybody is aware of please?
Does anybody know why it happens or what causes it? It looks like the UHD or HDR perhaps, just stops for a tenth of a second or so. I can't think why a box designed to cope with UHD should be unable to do so?
Any help gratefully received.
Regards,
Julian
Message posted on 05 Mar 2023 07:27 PM
Re: Flickering UHD Sky channels
@Julian+Anthony wrote:The TV screen flashes or flickers every now and then only when watching Sky UHD channels - very annoying.
Regards,
Julian
@Julian+Anthony not really noticed it to tell you the truth watched F1 weeked in UHD without issues Sky Q 2TB issued 2016
Would have watched the Liverpool v Manu in glorious UHD but was happy to watch in HD considering the score forgot to change over lol
Message posted on 05 Mar 2023 08:04 PM
What HDMI cable are you using?
Message posted on 05 Mar 2023 08:05 PM
Regards,
Julian
@Julian+Anthony it's not always a problem with the Sky Q box years ago a few different TV's makes and models had a similiar problem and it was solved by a software/firmware update to the TV's provided by the TV makers.
Last year certain models of LG TV's had a problem which was found to be a change in the chips used in the TV's again LG releasew a software/firmware upgrade which sorted the problems
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 07 Mar 2023 02:07 AM
HDMI cable is a good thought. I bought a new 4k 0.5m cable, but I can try some others to see if that makes a difference.
Thanks,
Julian
Message posted on 09 Sep 2023 07:45 PM
Did you get the issue fixed at all, in the end?
Message posted on 24 Dec 2023 07:37 AM
There is clearly a problem with quality control with some Sky UHD content. I've seen very bad flickering with The Blacklist and also Gangs Of London. I had it on Sky Q and now on Sky Stream and it is replicated on 3 different tvs. It is extremely distracting.
Message posted on 09 Jan 2025 10:57 PM
I have this problem with my Samsung TV. Model QE65QN900D . I've tried every setting the tv has, bought new cables hdmi 2.1. Also can't watch disney plus on the sky app, screen constantly goes black. Makes,me wonder my sky q,box is probably about 6 years old is it just dated technology? All the tv apps work great hd channels no issue uhd channels are really annoying I'm sure sky charge me for the pressure as well
Message posted on 26 Feb 2025 01:21 PM
Exactly the same flickering on all uhd channels, really annoying. No issues anywhere else with either hd or uhd content other than on my sky box, shocker.
Message posted on 26 Feb 2025 02:03 PM
They sent me a new box, had no effect. Had samsung support take over my tv and change some settings, no effect. Samsung want me to record it and email them the video. I've tried several Hdmi cables. The original hdmi cable that come with the sky box is the best. It is really frustrating. It can only be an input signal that's causing it
Message posted on 21 Sep 2025 05:56 PM
I've noticed this happening with mine. I've just purchased a new sky q 2tb box with uhd and a new Phillips TV 2025. I'm wondering if it could be the lnb? Or wideband one that's used for q? I've got a Greene king I think it is, hdmi cable and tried sky's pink one and neither stop this issue.
Message posted on 21 Sep 2025 08:15 PM
I persisted until last week but just cancelled UHD it was ruining my life im happy now. I think ill wait for a new version of the sky q box if they ever do one
Message posted on 21 Sep 2025 10:16 PM
@Slade5 wrote:I persisted until last week but just cancelled UHD it was ruining my life im happy now. I think ill wait for a new version of the sky q box if they ever do one
They won't
But the current boxes do UHD absolutely fine if the TV cooperates.
Message posted on 21 Sep 2025 10:24 PM
Given Comcast has decided streaming is the future, that's extremely unlikely. Satellite television broadcasting to the UK & RoI will probably cease before the end of this decade.
Message posted on 22 Sep 2025 02:24 AM
I'll refuse to swap to streaming. I love Q and I'm set in my ways with the TV guide and recording facility. I think I'll just persevere with UHD jumping. I only notice the sky sports box jumping, otherwise nothing, apart from the HDR message at the bottom. Brand new Philips TV also, so it's very strange.
