7
This discussion topic has been answered Discussion topic: Find Sky devialet controller
This message was authored by: SteveWo1970
I know you can find the remote control with Sky Q  by pressing the front of the box, but is there a similar feature with the Sky soundbox (devialet) ?
This message was authored by: Sally_Sparrow Answer
Re: Find Sky devialet controller
@SteveWo1970
No.
Avatar for SteveWo1970
lol fair enough
This message was authored by: best+of+the+best
@SteveWo1970 wrote:
lol fair enough
Hi @SteveWo1970 the other option if you can't find your Sky Soundbox remote
Is to connect a Firetvstick to your tv and use the FireTv remote to operate the Sky Soundbox
I rarely use the original Sky Soundbox remote as the Firetvstick allows me to use it to turn the Sky Soundbox off something the Sky Q remote fails to do
Apologies if you don't have a Firetvstick
Screenshot_20231216-132723_Amazon Alexa.jpgScreenshot_20231216-132723_Amazon Alexa.jpg
Cheers for the info. We managed to find the controller
This message was authored by: Home11
What app are you using for this?
@best+of+the+best  What app did you use for linking the firestick tv to the sound box?
Apologies for the late reply @Home11 I used the Manage Equipment within the FireStick settings menu found in Equipment Control
1 Select Manage Equipment via your Firetv Stick Settings
2. Select Add Equipment scroll down to Soundbar
3. Select Soundbar and wait for Which brand of Soundbar do you have?
4.Scroll down to Sky select Sky and follow the onscreen.
Answered - Go to Answer
