4
This discussion topic has been answered Discussion topic: Error code on Netflix and paramount +
This message was authored by: Adele43
I keep getting an error code on Netflix error code - tvq-pb-101(5.6.1) i have contacted Netflix and they say its an issue at sky's end. I never had this problem till I went though sky for Netflix! Also it works on every other device except my main sky q box.
I'm also receiving an error message on paramount + error code -3304 I have never had this before I have done the troubleshooting advised on the sky page to no avail and its getting tedious now!
I have been with sky 13 years and if this problem isn't sorted out I will consider leaving!
Re: Error code on Netflix and paramount +
There is a very simiar error message with a cause and possible fix here:
https://helpforum.sky.com/t5/Sky-TV/Error-Codes-on-Sky-Q-and-Glass/ba-p/4017045
Try closing the app then reloading it.
Avatar for Adele43
Thank you. I have tried what it suggests and its still the same.
This message was authored by: SHEP2022
I keep getting the the same error code, do all the recommendations power off then back on. Still occurs, spoke the sky, went through network reset, told I would be called back the following day to check if error has cleared. Did not get the call back so tried calling again then got a link to this forum.
Next thing. I will be requesting a replacement Q box, cannot keep powering the box off.  Been with Sky over 23 years
This message was authored by: DickFT
Unfortunatly still not working.
Error 3304 on Paramount+
NW-2-5 on Netflix
Both work fine on Amazon Firestick & nVidia Shield.
Sky have swapped boxes, but problem still there.!!
All connected in the same way. Hard wired via ethernet over mains directly to router.
Sky say its Netflix & Paramounts problem, who both then say its Sky's problem.
OK, i can still watch via Firestick & Shield. But it SHOULD work via Sky!!
