1
This discussion topic has been answered Discussion topic: New broadband provider and box won’t sync
This message was authored by: Teresa59
Installed new broadband provider and router today. Our main Q box has connected but our second in another room from the router won't connect enabling g us to get sky Tv. Any ideas how to set this up ?
This message was authored by: stereohaven Answer
Re: New broadband provider and box won’t sync
Your Sy Q Mini doesn't connect to your router, it actually connects to a WiFi network generated by the main Sky Q box.
If you have changed broadband provider you will need to reset the network connection on the mini box, but you are actually connecting it again to the main Q box.
Work through the steps here: https://www.sky.com/help/articles/sky-q-permanent-connectivity-problems-restart-mini-box
Make sure you use WPS to connect to WiFi when it asks as you need to press the button on your main Sky Q box, not your router.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
