Discussion topic: Error MR104
This message was authored by: Blake25
Error MR104
Our multiroom box not been working for 3 days now but the main box in livingroom works fine. Keeps coming up error MR104 and we've reset the box and turned off and on at mains and still the problem persists.
Re: Error MR104
@Blake25 have you also rebooted the main Q box
if not then reboot your main Q box ie
then
reboot your mini box
This message was authored by: Sjcw
Re: Error MR104
It's always reboot everything is the solution but what is causing this.
If it was too far away from the sky q main box surely it would have started happening from day 1 of installation? Why has it started in the 6 months?
I've seen multiple occurrences of this error recently and I have a wifi booster in the room where the mini skybox is situated so it shouldn't be too far from the main box.
Re: Error MR104
@Sjcw a reboot is recommended as in the majority of cases this works  you say you have a wifi booster who is your broadband provider and was the booster supplied by Sky if the booster was supplied by Sky it should be situated half way between your main Q box and the mini box
This message was authored by: Scoobysnax97
Re: Error MR104
The engineer came out today. The mini boxes were on a different network SSID to the main Q box.
Pressed the WPS button, Reactivated the mini boxes and working
There's 10 kinds of people in the world.... Those who get binary and those who don't
