17 Oct 2024 10:48 AM
I have Virgin Wifi for my main internet connection, and the a sky wifi box wired to that in the house - which works the TVs in the house fine.
We have a garden room which I have had a wifi extender wired to the main Virgin router (for internet again), how can I also get sky into the garden room for a mini box on the TV in there?
Thanks in advance for any advice.
17 Oct 2024 11:29 AM
Hi @Stuart_Mac
Certainly the mini will not work on 3rd party WiFi or 3rd party WiFi extenders.
If all your other Q boxes are on Ethernet to your router then you could use the Ethernet from your router in the Garden room. You would need a simple unmanaged Ethernet switch there so you could also connect your WiFi Extender.
17 Oct 2024 11:40 AM
Thanks so much for coming back to me @oldfella appreciate the help - the setup atm is Virgin Wifi as my main internet connection in the house, managed switch with the Sky Wifi box on Cat6 to that, then main Sky Q & 2 Sky miniboxes all over (SkyWifi) in the house, but all internet devices use the Virgin Wifi.
Then to the Garden room there is a Cable from the Managed switch to a POE Access point for the Virgin Internet connection, what I'd now like to do is put a sky minibox in the garden room, but the Sky Wifi doesn't reach - os there a away to extend the Sky wifi using the switch and the cable from the house, without losing the Virgin Wifi?
Sorry a convoluted set-up I realise but Virgin was the only (Gigabit) Wifi option where we are.
Thank you again, really appreciate the advice.
17 Oct 2024 11:51 AM
Posted by a Superuser, not a Sky employee. Find out moreLooks like the only way you could do this is to run the Ethernet directly from your main Q box to the mini @Stuart_Mac
However you will not have Virgin WiFi in the garden room unless you run another Ethernet cable.
