Discussion topic: Error MR102
This message was authored by: Wayne53
Error MR102
Hi all, we recently had a power cut. Now our additional 2 tv's on sky q have an error MR102. This happened on a recent power cut, I was told to reset the whole system but the engineer came out and said next time it would be better if I didn't do that as it took him ages to set up the whole system again. It is about to be half term from school so any help would be much appreciated. Thanks
Re: Error MR102
Hi @Wayne53
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Avatar for Wayne53
Re: Error MR102
Thanks for the quick response, last time this happened I tried to reset the sky mini boxes but that didn't work.
I have reset the main router (no extender in the house) and using the WPS I have the main tv working and connected.
I then turned off the mini's but I get the MR102 error.
Last time I reset all the mini's we had nothing for weeks.
Amy other suggestions
Many thanks
Re: Error MR102
Many thanks
Hi @Wayne53
You haven't mentioned rebooting the main Q box.
Avatar for Wayne53
Re: Error MR102
Sorry yes I rebooted the main sky q box also.
This now works fine
Re: Error MR102
This now works fine
When you say last time reset the minis what exactly do you mean @Wayne53
Avatar for Wayne53
Re: Error MR102
We had a power cut 5-6 months ago. At this time the sky customer service person said 'reset your minis on you menu on the main tv'. I did this for both minis.
This made no difference and did not solve my issue.
An engineer came out a few weeks later and he said if someone says that again do not do it.
After his visit he got one mini working, the other took a further 2-3 days until it finally worked
Re: Error MR102
Yes @Wayne53
I get all that, but you keep saying Reset the minis
Was this Reset Settings - Factory Reset - Network Reset. ???
Avatar for Wayne53
Re: Error MR102
Yes that's what they said to do
Re: Error MR102
You still do not specify which reset you did @Wayne53
Avatar for Wayne53
Re: Error MR102
So on the main box, I was told to reset the minis. This I believe was a factory reset
Sorry I do not remember which menu I used.
Re: Error MR102
Hi @Wayne53
I suspect you wer told to Reactivate the minis in the main Q box menu.
Suggest you try everything in my first post.
Either you want to get it working or Contact Sky for another ENGINEER VISIT
Avatar for Wayne53
Re: Error MR102
Ah ok, thanks for your help. I will go through you post
Thanks again for your help, much appreciated
