Discussion topic: Q box freezing and remote now working
This message was authored by: Charcole
The sky q box is making a lot of noise, remote and box don't seem to be synced. Channels staying black and recordings disappearing
Re: Q box freezing and remote now working
Hi @Charcole
Have you tried first rebooting your Q box?
Then if the remote has issues
