Discussion topic: Do not have internet connection
Message posted on 04 Mar 2024 09:30 AM
Sky says do not have internet connection right now.
Message posted on 04 Mar 2024 09:36 AM
What do I do now?
What do I do?!?
Message posted on 04 Mar 2024 09:57 AM
Re: What do I do now?
@Micellar1964 wrote:What do I do?!?
Is your router functioning? Any red lights on it? Who is your broadband provider?
Have you tried rebooting both the router and the Sky Q box?
Message posted on 04 Mar 2024 11:44 AM
Re: Do not have internet connection
