04 Mar 2024 11:53 AM
2 mini sky boxes not working.. main tv and 1 other mini sky box working no issues. I've tried to reconnect to sky internet but still wont work
04 Mar 2024 12:08 PM
Hi @Fr4
Reboot the mini as above. Start with the mini nearest to the main Q box.
As you are on Sky Broadband if the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
