1
This discussion topic has been answered Discussion topic: Distorted picture on ITV Sky q
This message was authored by: Cbbctv123
Distorted picture and then no signal just on itv
Re: Distorted picture on ITV Sky q
@Cbbctv123
No signal and no satellite signal messages are different…
A ”no signal” message tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
@Cbbctv123
