Discussion topic: New hub
This message was authored by: 107351009
New hub
I got a new hub now my skyq won't stay connected to the Internet
Re: New hub
Hi @107351009
Is that the new Sky Max fibre hub that you have?
Avatar for 107351009
Re: New hub
Yes it is x
Re: New hub
@107351009 wrote:
Yes it is x
Hi @107351009
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Re: New hub
Thanks I will give that a try x
