Discussion topic: Disney+ black screen
Message posted on 16 Nov 2024 11:26 PM
Re: Disney+ black screen
I meant what software version are you on?
Message posted on 16 Nov 2024 11:40 PM
Q270.000.10.09L(5u193ht)
Message posted on 16 Nov 2024 11:43 PM
I'm having this exact same issue, tried the 001 reset but that's not working for me although is because my remote isn't paired?
Message posted on 16 Nov 2024 11:52 PM
Successfully paired the remote, trying to refresh apps now.
Message posted on 17 Nov 2024 08:02 AM
@Trace+Em wrote:Q270.000.10.09L(5u193ht)
Yeah that definitely has the other fixes. Hmm strange that it works for others.
Message posted on 17 Nov 2024 08:41 AM
Is yours now working? Just wanted to ask before I try the reset option
Message posted on 17 Nov 2024 11:29 AM
This is happening to me and I've tried switching off the box etc, resetting the apps and still it's doing it. Please can SKY get in touch or atleast post an update on why this is happening. 3x days the app has been messing about as we have had to exit out of it because the program we were watching just suddenly went to a black screen and when we went back to it the app hadn't 'noticed' we had watched that episode or part it.
Message posted on 17 Nov 2024 11:40 AM
Re: Sky Q Apps pixelating
I've noticed pixelation is getting better but watching Disney app via sky box and it keeps cutting off, screen goes black and I need to restart sky box - just constant issues now
Message posted on 17 Nov 2024 11:47 AM
We're having to w same problem. Tried a box reset, app refresh, no luck.
only happening on the main W box, Disney+ still working on all the minis.
does anyone have any other suggestions other than waiting for a fix/update that may or may not come?
many thanks.
Message posted on 17 Nov 2024 12:17 PM
The only thing that worked for me was the hidden menu. Scroll to settings (don't press it) press 0 0 1 SELECT and this will bring up the menu. Select the reset option and it's the top of 3 options. This wipes all the apps and installs again after about 10mins. Mines worked okay then.
Message posted on 17 Nov 2024 12:19 PM
Yeah I tried that, still no luck.
This only started happening in the last week, I'll have to hope it resolves with an update in the future to either the box or the app.
Message posted on 17 Nov 2024 12:22 PM
Seems to be an issue with the SkyQ main box. Hopefully some type of update will fix.
Message posted on 17 Nov 2024 12:57 PM
Yep, getting the same black screens too in Disney.. only on the SKy box, and mine's new, only installed it last week.
Message posted on 17 Nov 2024 01:16 PM
Yes I'm only getting the issue with the main sky box not the minis so frustrating.
Message posted on 17 Nov 2024 01:51 PM
So I have just spoken to sky tech team, they have checked and told me that there is a compatibility issue with the sky q box and they are sending out another box, it works fine on my sky mini box so will let you know how I get on when I receive the new box 🤞
