162
This discussion topic is read only This discussion topic has been answered Discussion topic: Disney+ black screen
This message was authored by: Kellymm1
Disney+ has started to coming up with black screen when loading most programmes.
The app itself opens fine, login is there and can select the profile - can see the full menu and select any programme but when I go to play it, most come up with a black screen and does not play.
 It was working fine yesterday. Nothing has changed in set up.
I have tried a software update, app refresh and still the same.
Any suggestions?
This message was authored by: Daniel-F Answer
Re: Disney+ black screen
Posted by a Sky employee
Hi all,
Thank you so much for your patience whilst support teams looked into this issue.
Looking to jump in hear and update that the original issue with this was all UHD content not playing back on Disney+. An update was put out last week which resolved this specific issue. Most of the original customers who outlined as having this issue confirmed this was fixed for them last week.
I am seeing a lot of unique issues separate to the above being sent into the thread now and to avoid further confusion I'm locking this thread moving forward.
If you are still having issues with Disney+, please do try some troubleshooting steps found here to resolve this.  If the steps do not resolve the issue you are having, please check the discussion board for your own specific issue or if you do not see it, start a new thread detailing your exact issue in full.
Thanks,
Daniel
Community Moderator
Locked
This message was authored by: Nick992
Disney Plus
The app is loading and it displays all of the shows/films.
When selecting to play certain titles, the circle bar loads however the screen remains blank apart from the title of the show in white writing. There is no sound but it appears to be 'playing' since the time bar is visible when selected and shows the seconds moving.
If I pause or fast forward it shows me the film in the small square above the time bar only.
Some shows and films are working fine but others not.
Re: Disney Plus
Hi @Nick992
Have you tried rebooting your Q box?
Re: Disney Plus
I've now done this and the problem remains the same.
Strangely Disney plus loads all films fine using my web browser, playstation and smart tv. The problem only seems to be when using Sky Q.
Re: Disney Plus
Hi @Nick992
Have you tried refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
This message was authored by: Austinored
Re: Disney Plus
Yeah I have the same issue too. In fact another issue I have is Planet of the Apes on my watchlist, 5 of them I cannot remove after watching them. I've raised 3 requests to Disney without any success.
Update: I've raised it with Disney, we went through the usual trouble shooting protocols but it's the same issue. They will try and act on it but in the meantime I'm using my Xbox Disney App.
Panasonic 50cx700 sky q 2tb, keep the 3d films, I am still watching those
This message was authored by: Addie15
Hi there, @Kellymm1. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Roraldo
Re: Disney Plus
Having same issues with films. Strangely if you put subtitles on they show up but without pic and sound. Any series will be fine, seems to be films. Found no fix after rebooting all and refreshing all app on sky q.
This message was authored by: Joan36
Disney+ not working on Sky q
works on my other devices fine.
Re: Disney Plus
Strangely on my daughter's profile it works just fine, it's on mine it has the black screen and yes I can see the subtitles and if you fast forward it you can briefly see it in the little square window. Bit annoyed because their (and Sky's) prices have gone up and I'm not exactly reaping the benefits
Re: Disney+ not working on Sky q
Hi @Joan36
Try a Reset Settings in the main Q box hidden menu.
This message was authored by: Adam123456789
I have the same issue.  It works fine on the mobile app but I get a blank screen when I press play. I've tried the 001 option and it doesn't change anything.
Please can someone from Sky provide a solution
thanks
This message was authored by: Nick+Reffell
I have exactly the same issue - nothing has changed on network or box & can only navigate the menu or watch trailers.
The same Disney+ account works fine on mobile devices attached to the same network.
This message was authored by: Trace+Em
I also have the same problem since yesterday
This message was authored by: Jacqui171
Dosney
So is someone going to confirm there is an issue with disney on sky q, since yesterday, can play on other devices and can play trailers but cannot play films!!
Locked
