Discussion topic: Digital audio HDMI setting keeps changing back to normal
This message was authored by Daban+Urnud This message was authored by: Daban+Urnud
I have been experiencing this issue the last few days: every time I switch my Sky Q on from standby, the sound output has reset to normal (stereo PCM). I normally have it on the Dolby Digital Plus setting.
My Sky Q is a 1TB box originally connected with the supplied HDMI cable to my Denon AVRX2200W receiver. The receiver is then connected to a Philips 65OLED706 TV with a Kabeldirekt 2m HDMI 2.1 cable. CEC is enabled on all devices. ARC is enabled on the receiver and TV using the appropriate ports.
My speaker setup is 5.1. I also have a Panasonic 4K Blu-ray player connected to the receiver.
I have replaced the HDMI cable from the Sky Q to the receiver with a HDMI 2.1 cable. Then I disconnected the Blu-ray player, connected the Sky Q directly to the TV and I have tried resetting the Sky Q settings all to no avail. I do not currently have another AV receiver or TV I can use to test if it's not a fault with the Sky Q.
Does anybody have an ideas what else I can try or do I need to reset the Sky Q to factory settings?
Re: Digital audio HDMI setting keeps changing back to normal
Hi @Daban+Urnud
Factory reset is a bit of an overkill I would think.
Try a Reset Settings first in the Q box hidden menu.
Daban+Urnud
Thanks @oldfella I did reset settings already. Sorry I did not make it very clear in my original post.
This message was authored by Romy2907 This message was authored by: Romy2907
Did you get a fix for this? When I press home on my touch remote, the sound output changes to internal TV.  When I have Dolby turned on, certain channels have sound but no speech.  This is a new issue today, I have had this setup since the launch of Sky Q!
Daban+Urnud
@Romy2907 It resolved on its own a while back. I assume it was a firmware update.
