Discussion topic: my sky box keeps recording programmes i’ve not recorded
This message was authored by: aaronpage1979
my sky box keeps recording programmes that i've not set to record
Re: my sky box keeps recording programmes i’ve not recorded
Hi @aaronpage1979
Check your Recordings- Sheduled section to make sure you haven't inadvertently set any Series links
@aaronpage1979 are you accidently pressing the sect button when you are on a channel that you can watch from the start as apart from BBC which takes you to Iplayer the other channels with watch from the syart download the programme to your recorded section
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
