7
This discussion topic has been answered Discussion topic: Deleting recordings
This message was authored by: rond1
Deleting recordings
When I try to delete a recording, I get the message
This item is currently being watched and cannot be deleted right now
does anyone know this is?
Avatar for rond1
Level 3 icon
This message was authored by: rond1 Answer
Re: Deleting recordings
Thank you very much for this.
I've tried these and still got the same message after spending several hours, trying out things and researching things I took the technical. Nuclear option. I. E. Turned the skybox off and on and hey presto deleting the recordings worked.
Ron
Hi @rond1
You need to press the Dismiss button (left of Home button) once or twice to exit the recording before you can delete it.
Also recordings can only be deleted from Recordings - Most recent section.
Avatar for rond1
Level 3 icon
Ron
This message was authored by: House+mummy
It's when you have the recording playing on another box. Simply turn the recording off of the other box and then it will allow deletion on the other
Avatar for rond1
Level 3 icon
You are right. Thank you.
Avatar for rond1
Level 3 icon
Looking at this again, the bottom line is when you have finished a recording you have to come out of that recording and click on something else so that the top left-hand panel is not showing the recording you just watched.
This is a bit of a pain.
Have I got this wrong?
This message was authored by: FFS+MB
No, none of the answers above solve the basic problem. Dismiss does not end the recording for deletion. It is a logic fault in the design of the interface which needs fixing. Simples.. stop. delete .
@FFS+MB emm it works on my box dismiss ends the recording then i can scroll down to delete and delete the recording
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
