This discussion topic has been answered Discussion topic: Deleting recordings
Message posted on 06 Apr 2023 09:53 PM
When I try to delete a recording, I get the message
This item is currently being watched and cannot be deleted right now
does anyone know this is?
Message posted on 07 Apr 2023 08:12 AM
Thank you very much for this.
I've tried these and still got the same message after spending several hours, trying out things and researching things I took the technical. Nuclear option. I. E. Turned the skybox off and on and hey presto deleting the recordings worked.
Ron
Message posted on 06 Apr 2023 09:55 PM - last edited: 06 Apr 2023 09:56 PM
Re: Deleting recordings
Hi @rond1
You need to press the Dismiss button (left of Home button) once or twice to exit the recording before you can delete it.
Also recordings can only be deleted from Recordings - Most recent section.
Ron
Message posted on 07 May 2023 12:52 AM
It's when you have the recording playing on another box. Simply turn the recording off of the other box and then it will allow deletion on the other
Message posted on 07 May 2023 07:30 AM
You are right. Thank you.
Message posted on 27 Jun 2023 12:45 PM
Looking at this again, the bottom line is when you have finished a recording you have to come out of that recording and click on something else so that the top left-hand panel is not showing the recording you just watched.
This is a bit of a pain.
Have I got this wrong?
Message posted on 05 Sep 2023 09:06 PM
No, none of the answers above solve the basic problem. Dismiss does not end the recording for deletion. It is a logic fault in the design of the interface which needs fixing. Simples.. stop. delete .
Message posted on 05 Sep 2023 09:43 PM
@FFS+MB emm it works on my box dismiss ends the recording then i can scroll down to delete and delete the recording
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
