Discussion topic: Deleted programs n its management
This message was authored by: Venom1979
The sky q software needs to be updated with the aspect of confirm delete and selection aspect towards recordings. U delete from page, then have to manually permanently delete Again!
Just to save space you have spend 5-10mins deleting the deleted programs.
Re: Deleted programs n its management
@Venom1979 the Q box will automatically delete programmes that are in the deleted section so you don't need to worry about that
Hi @Venom1979
As @Laing1 the system automatically reuses space and you do not need to go into the manage - deleted section to delete permanently to free up space.
Most customers never use this option and probably aren't even aware it is there.
Avatar for Venom1979
Thanks everyone for ur replies. Learn somat new everyday.. 👍
