Discussion topic: my multi room sky box is not working
Message posted on 17 Jul 2024 12:41 PM
multi box is not working in bedroom
Message posted on 17 Jul 2024 12:55 PM
Re: my multi room sky box is not working
What's happening? Any error message? 'Not working' doesn't give us a lot to go on.
Message posted on 19 Jul 2024 06:47 AM
Hi multi room box is not connecting to main sky box
Message posted on 19 Jul 2024 07:18 AM
@Susangriffin
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
