Discussion topic: Damaged external cable
This message was authored by: Ei+May
I have damaged an external Sky cable
Re: Damaged external cable
@Ei+May
If you want Sky to carry out a repair you'll have to call them. The charge would be around £65.
HAPPY NEW YEAR
Avatar for Ei+May
Is it dangerous if it's just snipped
no, it is not dangerous
This message was authored by: Invisiblename
If you've only "snipped" the outer covering of the dish to Sky Q box cable, and there is no loss of signal on any of your channels, you could get away with just wrapping insulation tape around it to keep moisture out
I am just another Sky customer!
