Discussion topic: Could not connect to your broadband
This message was authored by Mejulieshnaff This message was authored by: Mejulieshnaff
My tv took ages to turn on
now it won't connect to my internet
Re: Could not connect to your broadband
Hi @Mejulieshnaff
Mejulieshnaff
Hi @Mejulieshnaff
Thanks, but I have tried all this.
I have  turnt everything off, I've typed the password in 8 times .. keeps saying "won't connect"
My broadband is working fine, my son phone is connected
it is only the sly glass tv that won't connect
I don't know what else to try
Hi @Mejulieshnaff
If you have Sky Glass you are posting on the wrong forum.
Do you have Sky Q ?
