Discussion topic: Constant picture break up?
This message was authored by: Burcott72
Constant picture break up, sound goes, tried switching on & off repeatedly has made no difference. Can't be weather related for this long surely??
Re: Constant picture break up?
If you have your own dish then you probably need Sky to check the alignment.
Hi @Burcott72 are you using the HDMI lead provided by SKY, or a different one?
