Discussion topic: Constant failure to access recordings or programmes
Message posted on 31 Mar 2025 07:32 PM
Every time I go to watch my Sky Q I get error message: Sorry, there are currently no programmes of this type available.
My connection is good, all apps up to date, no issues in settings. So every time I am having to reset/reboot everything and wait for it to work. Can't get hold of anyone to speak to and the advice online is just to reset/reboot which I am fed up with doing every time I want to watch TV
Message posted on 31 Mar 2025 07:52 PM
Re: Constant failure to access recordings or programmes
Hi @Ducey67
Message posted on 01 Apr 2025 12:38 PM
Thank you for the reply. Unfortunately pressing 0,0,1 doesn't seem to work. I have already tried:
reset before (twice)
updating the software (once)
re-pairing the remote (several times)
rebooting the whole thing including the hub (several times)
Sometimes it works - sometimes it doesn't telling me there is a technical issue with my sky Q box, but even when I do get it working - the next time I turn on the TV the orange light comes on and I have the same issue again. Losing the will to live with it
Message posted on 01 Apr 2025 01:49 PM
Hi @Ducey67
When you say 0 0 1 doesn't work, did you complete the Reset settings ?
ie you need to press Select after the 0 0 1
Message posted on 01 Apr 2025 01:55 PM
I am very old! I would really like to talk to a human rather than all this stuff which I find very unhelpful. My Sky Q box has been going on and off for a few weeks now and my only remedy seems to be to unplug the thing, leave it for a while then switch it back on again, but this does not work every time. When this happens I cannot access any of the Sky services you are contracted to supply and for which you continue to charge me. Can someone from Sky contact me and/or just resolve my problems.
Message posted on 01 Apr 2025 02:02 PM
Hi @Howard26
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
