Discussion topic: Connectivity problem -
Message posted on 10 Apr 2023 09:05 PM
Hi, with my Skyq mini box, my TV says - you can't watch TV at the moment as there is a connectivity problem.
Thank you
But the settings say I have both connection to Sky Q box And, Network connection.
Any ideas ? Sky Q main box working fine.
Message posted on 10 Apr 2023 09:09 PM
Re: Connectivity problem -
Thank you
Hi @Jacqui1608
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
@Jacqui1608 Try unplugging both mini & main Q box, then plug main Q box in again, let is fully reboot then do the same with the mini.
Message posted on 25 Apr 2023 12:30 PM
I kept losing connectivity to Sky Q mini in my bedroom. Pain as had to keep re conecting. Parring up and switching on an off at the wall. In the end I got so fed up I got a TV man in, he said the strenght from the Mini box just isnt strong enough, this is a common problem. What he did was set up an ethernet connection to The Sky Q box so we do not rely on Wifi as we have a constant connection . Since then it has remained connected all the time and in the morning I can have Tv on from Sky Mini without having to re start the Q box downstairs first. Unfortunately this did cost me £200 but at least it has saved the problem as I could be watching something and it stop mid program. It drives you mad if you want to watch something and have to keep going through the same problems. Hope this helps someone
Message posted on 16 Oct 2024 03:04 PM
Having the same issue also. Currently waiting for mini to reload. Absolute joke. Had them out already. 300 full fibre and 2 boosters later and it still looses connection as do many other devices
Message posted on 26 Oct 2024 11:23 AM
We are having the same issues seriously yhinking of binning Sky altogether paying £102 for a service you dont get. Bang your head off a wall it eventually hurts.
Message posted on 14 Nov 2024 09:34 PM
Likewise, constant connection issues. WiFi in and out. Simply not good enough for the price we pay. Time for Sky to go I think.
Message posted on 23 Nov 2024 04:23 PM
Have the same problem at least once a week. Never had any issues when I just had standard 30mps bro, since I upgraded my broadband to full fibre 500gb I have encountered connectivity problems. Mini box is connected by ethernet cable to router. Sometimes I have to reset 3 or 4 times before it works.
Message posted on 23 Nov 2024 06:34 PM
Ours started shen we went to full fibre to. Although we have multiroom and one of the mini boxes i think is the issue as we have disconnected it and have had no trouble this was found out after the last post
Message posted on 25 Jan 2026 06:07 PM
Yip.. absolute nightmare at times..I wish I never took out sky....sometimes you just want to just chill after work or whatever.only to switch on and discover Sky doesnt work.. then its Such a hassel trying to get it going...on the verge of telling them to ram it...
