10 Apr 2023 09:05 PM
Hi, with my Skyq mini box, my TV says - you can't watch TV at the moment as there is a connectivity problem.
Thank you
But the settings say I have both connection to Sky Q box And, Network connection.
Any ideas ? Sky Q main box working fine.
10 Apr 2023 09:09 PM
Thank you
Hi @Jacqui1608
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Posted by a Superuser, not a Sky employee. Find out more@Jacqui1608 Try unplugging both mini & main Q box, then plug main Q box in again, let is fully reboot then do the same with the mini.
25 Apr 2023 12:30 PM
I kept losing connectivity to Sky Q mini in my bedroom. Pain as had to keep re conecting. Parring up and switching on an off at the wall. In the end I got so fed up I got a TV man in, he said the strenght from the Mini box just isnt strong enough, this is a common problem. What he did was set up an ethernet connection to The Sky Q box so we do not rely on Wifi as we have a constant connection . Since then it has remained connected all the time and in the morning I can have Tv on from Sky Mini without having to re start the Q box downstairs first. Unfortunately this did cost me £200 but at least it has saved the problem as I could be watching something and it stop mid program. It drives you mad if you want to watch something and have to keep going through the same problems. Hope this helps someone
