10
This discussion topic has been answered Discussion topic: Connecting to Sky mini box
This message was authored by: Pistol2
Every morning wake up to the the same blue sceen saying my router is not connected.
Never had these problems before now all of a sudden it is daily
Re: Connecting to Sky mini box
@Pistol2 wrote:
Thanks for sharing, same process I am following every morning. Works most times but frustrating have to do this daily
Hi @Pistol2
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max white router then you need to connect the WPS to the main Q box.
Hi @Pistol2 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with the Mini box?
Avatar for Pistol2
Hi @Pistol2
This message was authored by: gypsyroadhog
Hi,
rather than post new question thought I'd search and found this one....
I have same problem, reset mini box, Q and router several times with no joy
I can connect to my Q box downstairs with my phone as all my recordings are on the Sky Go app but the box won't stay connected
is a wifi extender/mesh the answer....all though as router is immediately at the bottom of the stairs to our bedroom it shouldn't need one
cheers
@gypsyroadhog wrote:
Hi,
cheers
@gypsyroadhog firstly is Sky your broadband provider ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Nope
i had problems connect Q box to router as apparently doors and cabinets block the signal so YouFibre connected an extender on Q box now that's fine, it's just the mini box where the problem is
thanks for reply
Nope
thanks for reply
@gypsyroadhog as \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\sky is not your broadband providers if connecting thr mini boxes by wifi you need to connect them to the main Q box by using the WPS button
Cheers for reply
Done all that many times and it does connect, the issue is maintaining the connection as it loses the signal....picture begins freezing then goes entirely with the dreaded blue screen regarding the message that there's an issue and unable to connect
Cheers for reply
@gypsyroadhog if thats the case it maybe the boxes are just on the edge of range for receiving the signal from the main box. You may need a booster to put between you main box and mini box but you need to contact Sky for this
Hi thanks for that and sorry for lateness in reply as was having WiFi problems but provider has installed a whole new system as found issues with the previous one.
I'm defo going to contact sky as just reconnected both boxes for it to last a full 20seconds and if they don't help then the mini bix is going back
thanks again
Answered - Go to Answer
