Discussion topic: Code WGT8 widget 1.64.0
Message posted on 26 Aug 2024 10:48 PM
Trying to screen Rugby League on sky sports+. When I press red button get an error code WGT8 widget 1.64.0
Message posted on 27 Aug 2024 07:31 AM
Re: Code WGT8 widget 1.64.0
i recently got a mini box and had the same error ....
i resolved it by updating the software on it .....
go to settings then system info then software version /setup and update it ....
be patient, looks like nothing is happening for about 20 mins but it'll finish .... quick restart and good to go
Message posted on 27 Aug 2024 07:35 AM
forgot to mention about refreshing apps afterwards ....
go to settings but don't click on it -- enter 001 then press enter on your remote -- go down to apps -- select refresh apps and that's it done
Message posted on 27 Aug 2024 07:14 PM
Thank you so much brid+dave. Did as you advised and everything up and running perfectly. I'm 68 and not very tech savy and would never have figured it out without your help so once again thank you. Take care Jim 680.
Message posted on 27 Aug 2024 07:55 PM
No problem ....
Like I say I'm new to the sky mini setup ....
You'll probably have viewing issues while watching the app - freezing, I'm lead to believe this is a problem at sky's end and us as users will have to live with it until an update solves the problem
