3
This discussion topic has been answered Discussion topic: Blue screen on multiroom
This message was authored by: stevieg+1958
Sky multiroom goes to blue screen and then goes  back on but it does it regularly it's been doing it a few weeks
Re: Blue screen on multiroom
Hi @stevieg+1958
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini as the Network reset will start the mini WPS automatically ).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.  Make sure you press the WPS button on the Sky router and not the reset button.
Hi @stevieg+1958
Avatar for stevieg+1958
Just done it seems to be ok now many thanks
This message was authored by: Peteh1979
I have same issue I have rebooted  and tested the wifi still not fixing the issue  any other ideas
