Discussion topic: Chicago fire
This message was authored by: Lynette3
Chicago fire
Why does my sky q freeze up half way watching the new series of Chicago fire, happened in first 2 episodes already, have to turn box off and reset each time, but still unable to continue with episode.
Re: Chicago fire
@Lynette3
Downloads or recordings? We've watched the first two episodes (recorded) without a problem.
Avatar for Lynette3
Re: Chicago fire
Recorded
Re: Chicago fire
@Lynette3
What about the other Chicago franchise's if you record those too? Does it do the same if watching it live?
Avatar for Lynette3
Re: Chicago fire
No, it doesn't happen to Chicago med
Re: Chicago fire
Are you recording the early morning broadcasts, if so try recording the evening ones instead to see if the same thing happens.
Avatar for Lynette3
Re: Chicago fire
It records them on evening
Re: Chicago fire
@Lynette3
I've seen no other posts about recordings of Chicago Fire or indeed any recording problems of just of one programme so seems like an issue with your set up/ dish.
Avatar for Lynette3
Re: Chicago fire
I deleted the recorded version, then downloaded it, was able to watch it fine this time, thx
This message was authored by: Del1954
Re: Chicago fireMy sky q won't link Chicag fire, but links pd ans med
My sky won't link Chicago Fire, but links med and pd, sort it out I'm paying a fortune for your broadcast
@Del1954
Same here. You may want to notify the Viewer Relations Team by emailing them at viewerR@sky.uk
This message was authored by: Invisiblename
This is a user helps user forum, not sure what you expect us to do?
I am just another Sky customer!
This message was authored by: Ray+Keenan
Re: Chicago fire
I had a real problem with series links and the Chicago franchise this series, namely that it would not series link. All  three shows would not pick up their series link no matter how many times i reset them. I emailed the viewers email and because apparently their series links worked fine, they couldn't help (also had an issue with Fire Country and the fact it kept setting the series link for the repeat and not the new episode funnily enough also shown on Sky Witness channel)
What seemed to do the trick for me is resetting the series link for the early hours airings of the new episodes- ie 1am Friday morning etc and those links work fine for me.  So maybe instead of setting the link for the 9pm Friday evening broadcast, set the link for the 2am Friday morning airing instead and see if that helps?
