Discussion topic: Channel 4
This message was authored by: Coventrykid
Message posted on 19 Nov 2023 01:28 PM
Channel 4
Since having Sky Q, channel 4 pixelates, all other channels are fine
Find out more
Message posted on 19 Nov 2023 02:18 PM
Re: Channel 4
Have you tried rebooting your main Sky Q box? If that doesn't help your dish might be slightly out of alignment in which case take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
