Discussion topic: Changed broadband, Sky q now not working
This message was authored by: Chrisl1210
Hi
We've recently had youfibre installed at the house, I turned off the Sky Q Router/hub and the Sky Q box, I renamed the new WiFi to the old one, everything worked, connected to the WiFi straight away etc, then I turned on the Sky Q box.
It took a couple of attempts to get it to connect to the WiFi but it did, however we have lost satellite signal.
I have pulled the power out, left it a few minutes, even done the reset using Settings, 0, 0, 1 menu, however I still have the No Satellite Signal on a black screen, all menu options, such as Records, Catch Up, On Demand, Cinema, Apps just say To Use This Service, you need a satellite signal.
Does anyone have any suggestions I can try?
Re: Changed broadband, Sky q now not working
@Chrisl1210 wrote:
Hi
Hi @Chrisl1210
Do you have your own dish or are you on a communal system?
Avatar for Chrisl1210
Hi, it's our own dish.
OK @Chrisl1210
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-q.
Thanks, engineer booked as I've still got the same issue.
