This discussion topic has been answered Discussion topic: Sky Sports Golf HD not being recorded
Message posted on 06 Dec 2023 08:13 PM
I have Sky Sports golf package to record the DP world Tour and PGA tour 4 day competitions.
I am finding the games are not always being recorded. Like today under Sky Sport - Golf - catagories - DP world tour day 1-3 is shown as Sky sports main event (which when selected will not record as failed subscription - I have Sky Golf HD). However, it shows DP World Tour day 4 and will allow to record. But where is day 1-3.
I have had this problem before and had a new recording device sent and a full reload of upgraded software but it is happening again.
This is highly frustrating as this is the principle reason for having Sky.
Any help appreciated ASAP.
Rgds
Message posted on 06 Dec 2023 08:39 PM
Rgds
hi @Keith_M
SKY Sports Main Event is a mix of sports and usually simulcasts broadcasts on other channels
I don't think anything on Main Event will Series Link
Also do you have UHD - so is the Main Event channel you are trying to set the UHD version - if so & you only have SKY Sports Golf rather than SKY Sports Full pack there is a possibiity this might be getting confused ( We have known this happen with Football where some customers only have the football) - Even without UHD I guess trying record from ME may also have foibles for Single Channel sports subscribers)
I am fairly confident that the DP World Tour is currently shechduled on the main SKY Golf channel so I suggest you make sure your recordings are set from there.
I have also known Series Link is not always set as it should be with the Golf (I often set for the LPGA for instance - although LPGA tournaments have a habit of being on different channels for different days as well) so always wise to check & if necessary set for each day manually
Rgds
hi @Keith_M
Message posted on 06 Dec 2023 11:20 PM
Re: Sky Sports Golf HD not being recorded
@Keith_M If you only have Sky Sports Golf as a single sports channel you can't watch (or record) Sky Sports Main Event. It's only available to full Sports subscribers.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
