Discussion topic: Change input using my Sky Q remote
Message posted on 30 Nov 2024 02:14 PM
My sky q remote is paired to my tcl tv however when I press the input button I cannot change to a different input, the input button or the up/down buttons do not allow me to change the input.
Message posted on 30 Nov 2024 02:55 PM
Re: Change input using my Sky Q remote
Hi @degzee1 It should move down every time you press the input button.
Message posted on 30 Nov 2024 04:13 PM
@degzee1 as @MightyQuinn says press the source button it should bring up your sources each susequient press should move through your sources. To select the source you leave it on the source you want and after 3 seconds it should automatically pick that source but some TV's need you to press select to select the source if your TV is one of these then unfortunately you will not be able to do this with the source button on the Q remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
