Discussion topic: Certain Channels No Satellite Signal
This message was authored by: Lainey1888
I haven t been able to access BBC1 via my sky box for a while now. Channel 5 is now getting interference and I can no longer watch Crime & Investigation channel saying "No satelitte signal"
Re: Certain Channels No Satellite Signal
@Lainey1888
If you see a “no satellite signal” error message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️very heavy rain
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 adverse weather can affect the satellite signal and following such events wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
This message was authored by: JPHorsham
I have problems connecting certain channels mostly BBC, but some others too. Also the Sky Q box keeps freezing and I have to restart it. Sometimes the only solution is to unplug the power wait for box to restart
