Discussion topic: Catch up tv
Message posted on 26 Sep 2025 04:53 PM
Catch up tv
my catch up tv and down loading catch up tv isnt working anymore on my Sky Q. when I try to use it, a banner come across the top of my screen saying " We have trouble reaching this service right now, don't worry we will keep trying " and just goes back to main menu. I have a good internet connection. I have rebooted my Q box, removed and cleaned and refitted my card, but still the same issue.
Message posted on 26 Sep 2025 06:25 PM
Re: Catch up tv
Hi @Tonygnu
have you checked in Settings in the Home menu that your Q box is connected to the Internet.
Home - Settings - Status.
Does Network connection have a tick??
Regardless, try completely resetting your. Box connection.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 30 Sep 2025 08:43 PM
Re: Catch up tv
my sky box is connected to my router, which is connected to the internet, Still I have the issue.
