8
This discussion topic has been answered Discussion topic: Can’t record anything
This message was authored by: Mark853
Can't record any tv programs
Avatar for Mark853
This message was authored by: Mark853 Answer
Re: Can’t record anything
I've pulled out the power lead and reset the box , everything is back to normal.
thanks very much everyone for your help
@Mark853
What happens when you try?
@Mark853 do you get any error messages
Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Mark853
It says due to a technical issue your download couldn't be completed
@Mark853
So it's a download rather than a recording?
Avatar for Mark853
I can try that
Avatar for Mark853
I can't do either
@Mark853
With a failed download cancel it, then make sure the download isn't sat in the 'deleted folder'. If it is delete it from there as well before trying again.
Avatar for Mark853
