Discussion topic: Confused about a house move
This message was authored by: Val+Duguid
My mum has dementia .... owe have moved home but I wanted to keep the old house until the end of a the month so I could take my mum there tonwqrch tv together transition
The lease on the old house ends end of Jul y
i do not want to lose all her recordings as this helps her dementia
Re: Confused about a house move
As long as you maintain the Sky Q subscription, the recordings will remain accessible on the main Q box (which you take with you to the new address)
The box does have to be connected to a compatible satellite dish though.
Unfortunately if you give up Sky Q you'll lose everything on the hard drive: this will also happen when Q is no longer a supported platform which is likely to be in the next few years.
