Discussion topic: Can't pick my match
This message was authored by: bodvoc79
Can't pick my match
I want to pick my match on sky+ but it only works in the main room not on multiroom
Re: Can't pick my match
@bodvoc79
Are you talking about Sky Sports+ on channel 412?
Avatar for bodvoc79
yes
@bodvoc79
You've posted on the Sky+ board so i have to assume that's what you have. Customers with Sky+ (with the full sports subscription) will receive the new Sky Sports+ Channel (412), but will not have access to the live streams as Sky+ is not compatible with the Sky Sports App.
See the article in the News section at the top of the page
https://helpforum.sky.com/t5/Sky-TV/Introducing-Sky-Sports/ba-p/4706785
Even though the SKY box doesn't support the new Sky Sports app that is showing the alternative games you can use the app on a mobile device such as iphone/ipad or Android mobile or tablet (but unfortunately not on a desktop).
Avatar for bodvoc79
No daniel i can only watch the main match on sky+ on the tv in the other room , if you try to select another match all you get is a technical isssues message
@bodvoc79
You can only watch the broadcast match not alternatives.
@bodvoc79  @Daniel0210  is correct there is no longer red button functionality on sky plus boxes
to access the extra games via the red button you need to upgrade to either sky Q glass or stream
Avatar for bodvoc79
I've got skyq
You can only watch the match that is being broadcast on the channel, you cannot use the red button on a Sky Plus box
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@bodvoc79 wrote:
I've got skyq
You should have posted in the Sky Q forum and NOT the Sky+ one 😞
Avatar for bodvoc79
sky+ issue
I'm trying to pick my match on sky+ but it only works in the main room not on multiroom
@bodvoc79
I did try to clarify this
@Daniel0210 wrote:
@bodvoc79
Re: sky+ issue
Hi @bodvoc79   Do you mean Sky Sports+?
Re: sky+ issue
@bodvoc79
What would help to prevent the confusion is your post above reading
@bodvoc79 wrote:
I'm trying to pick my match on Sky Sports+ but it only works in the main room not on my mini box
Multiroom is a term relating to Sky+ subscriptions. On Sky Q it's Multiscreen.
Avatar for bodvoc79
Re: sky+ issue
okay mate but what ever its called the match choice selection only works in the main room
