Discussion topic: Can I use sky without a satellite dish
This message was authored by: LisaMarie66
I currently have a Sky satellite dish an a Sky Q box.  I am sure someone told me that customers can access Sky service now without a dish.  We are having a new conservatory and we will need to relocate the dish if we still need to have it.
I guess what I need to know is, can I access Sky without a dish?
Re: Can I use sky without a satellite dish
hi @LisaMarie66
THere is now a product called SKY Stream where you can get SKY via internet.& doesn't use a dish
You need a good stable internet connection.
It is also quite different in a few respects to SKY Q as there is no hard disc recording & it uses apps for catch up and uses Play lists to track programmes etc. - do research it fully as whilst many like it, it doesn't suit everyone
(There is  a separate SKY Stream group which you may want to look through)
@LisaMarie66
Yes - Sky Stream or Sky glass but research fully first as it's a totally different way of viewing.
▪️I AM NOT A SKY EMPLOYEE ▪️
Hi @LisaMarie66
See following link for Sky Stream FAQ's
https://www.sky.com/help/articles/sky-stream-faqs
Avatar for LisaMarie66
I find it really hard finding the information I need on skys website it's not easy to navigate or find anyone i can just talk to. Do you know the pros and cons?
There are various opinions if you search @LisaMarie66
For example
https://moneytothemasses.com/quick-savings/utilities/sky-stream-review-how-does-it-compare
