Discussion topic: CNN not working
This message was authored by: JohnDeely
CNN not working
CNN Channel 506 is not working, we have no issues with weather - all other channels ok.
Do you know why this is?
Re: CNN not working
Hi @JohnDeely
Have you tried rebooting your Q box?
Failing this are you seeing anything when you select the channel?
Avatar for JohnDeely
Re: CNN not working
Thanks so much for your response! Yes, I have rebooted the box a number of times.
CNN goes fuzzy and then I get a message that there is issues with the satellite , Its odd that its just CNN so I was wondering if anyone else has the same issues.
Re: CNN not working
@JohnDeely
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Re: CNN not working
When you have problems with CNN, check Bloomberg (502) and GB News (512). They are broadcast on the same frequency. If they are also  affected that would confirm a dish alignment issue.
Re: CNN not working
Thanks everyone, that did not work so I booked an engineer to come out and check it
