Discussion topic: Reset hard drive; pressing 0,0,1 has no effect
Message posted on 04 Nov 2024 01:15 PM
Advise says press 0,0,1 (on hand set?) to reset but this has no effect - anybody able to help?
Message posted on 04 Nov 2024 01:19 PM - last edited: 04 Nov 2024 01:19 PM
Re: Reset hard drive; pressing 0,0,1 has no effect
Hi @clayts5765
Resets are in the hidden menu
Message posted on 04 Nov 2024 01:47 PM
If the hard drive has failed then reseting it won't fix it. (Or may mask the issue for a while)
