Discussion topic: Broken sky Q mini box
This message was authored by: LizzieJean
I need a replacement mini box.  Somehow the remote control sensor at the front has been pushed in and it's no longer working.  Does anyone know how I order a new one?
Re: Broken sky Q mini box
@LizzieJean
You'll need to call Sky and log a fault.  Given that sounds like physical damage rather than a hardware or software fault they may wish to charge an appropriate fee for replacement.
Someone thought it was the power button presumably. Not the first time. Bad design.
Avatar for LizzieJean
Thanks, I'm having problems finding a number to call.  Any idea where I can find that?
You can order a replacement mini box online using the link in this Sky help article.
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
if you prefer to call.
You can call on 150 from a Sky Talk Line or Sky Mobile.
Scroll down and click on ‘Need more help’ and it provides a 0333 number.
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. A some of the quieter times to ring are early morning or late evening.
