Discussion topic: Sky Q box needs reset (reboot) every time i switch it on.
Message posted on 28 Apr 2025 04:09 PM
Sky will not switch on unless I reboot it. Every time.
Message posted on 28 Apr 2025 04:18 PM
Re: Sky Q box needs reset (reboot) every time i switch it on.
Hi @Sky43 How are you switching it on, have you tried the power button on the box itself? This will rule out a problem with the remote.
Message posted on 28 Apr 2025 05:19 PM
Hi it won't switch on with the remote or on the front of the box. Only after a reboot. Works fine after that untill you switch it off. Then you have to start again.
Message posted on 02 May 2025 09:22 AM
- Yes I've tried the remote and sky box. Nothing happens till you reboot it.
Message posted on 02 May 2025 09:28 AM
Can you do the recovery procedure as described in this Sky help article;
Might also be wise to do a repairing of your Sky Q remote;
Hold down 7 and 9 until the remote's light flashes 4 times to factory reset your remote.
Then you need to pair it again:
- Hold down 1 and 3 together
- Select Continue and follow the on screen instructions.
