Discussion topic: Bluetooth and sky Q
Message posted on 08 Apr 2023 05:25 PM
Bluetooth and sky Q
Is there any way I can listen to my sky q thru Bluetooth headphones as my husband finds I have it too loud.
Message posted on 08 Apr 2023 05:33 PM - last edited: 08 Apr 2023 05:35 PM
Re: Bluetooth and sky Q
Hi @MrsB23 As far as I know the Sky Q boxes do not have a Bluetooth transmitter apart from finding the remote. You need to connect your Bluetooth headphones to your TV or Audio system. You could experiment with an Optical to Bluetooth transmitter connected to the Sky Q optical output.
Message posted on 18 Jun 2023 10:30 AM
Hi Mrs B23
Ignore connecting the earphones to the skyQ Box, connect them direct to the TV via bluetooth.
Hope this helps
Pete
Message posted on 18 Jun 2023 10:52 AM
@Peter+Waugh wrote:Hi Mrs B23
Hope this helps
Pete
@MrsB23 Yep, this works for me
Message posted on 12 Jul 2023 09:35 AM
Press Home on your Sky Q remote, select Settings, then Setup.
Select Music, then Bluetooth devices, and Add a new Bluetooth device.
Turn on Bluetooth on your device then follow the on screen instructions to confirm the connection.
Select Add this device on your Sky Q box.
The box name will be the type followed by the last four digits of the serial number
Message posted on 12 Jul 2023 09:42 AM
Hi @David+Mills This will only allow you to play music via bluetooth from a device to your SKYQ box, and not sound from the SKYQ box to headphones.
Message posted on 28 Dec 2023 01:34 PM
This is only to be able to play from a Bluetooth device through your TV. The question asked was the opposite; being able to listen to audio through e.g. Bluetooth earbuds or headphones.
Message posted on 28 Dec 2023 01:57 PM
@Wetken wrote:This is only to be able to play from a Bluetooth device through your TV. The question asked was the opposite; being able to listen to audio through e.g. Bluetooth earbuds or headphones.
Yeah that's what the 5 month old post above yours says
Message posted on 28 Dec 2023 02:12 PM - last edited: 28 Dec 2023 02:13 PM
Hi @Wetken There is no bluetooth audio output from the SKYQ box
