Discussion topic: Blank screen with audio
This message was authored by VK_Sky This message was authored by: VK_Sky
Hi,
 I recently got a new Sky Q Box. Randomly my TV will turn blank with sound in the background. I have tried a new HDMI cable and reset the sky box. When ever I switch the TV off and then turn it back on, its the same issue. It seems that the new Sky box is bugging with the TV. Can anyone help?
Thanks!
Re: Blank screen with audio
@VK_Sky wrote:
Hi,
Thanks!
Hi @VK_Sky
When you say
When ever I switch the TV off and then turn it back on.......
are you referring to your Television set or your Q box?
Also
Have you checked that you are on the latest Q software?
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
VK_Sky
Hi @oldfella,
I'm referring to the Q box. Do you recommend updating the software?
@VK_Sky wrote:
Hi @oldfella,
Only if it is not up to date @VK_Sky
All the info is in the links I posted
VK_Sky
Hi @oldfella
The software is up to date. Are there any other options to solve this issue?
@VK_Sky wrote:
Hi @oldfella
Ok @VK_Sky
When you say switch the Q box on assume this is from Standby and you are not switching it off  at the main switch?
This message was authored by Chodley This message was authored by: Chodley
@VK_Sky wrote:
Hi @oldfella,
You said TV though - if you really did mean Q box, sounds like the video signal isn't syncing properly when the box wakes up.
what TV is it and are you going via a soundbar or amp?
