Discussion topic: Re: Keep freezing
This message was authored by: Harty2334
Re: Keep freezing
My netflix has been freezing, sometimes just shutting down. I've reset apps etc but nothing helps...anyones else got the same issue?
Re: Keep freezing
Hi @Harty2334 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Avatar for Harty2334
Re: Keep freezing
Tried all the tricks but no  change . Thank you though.
Re: Keep freezing
Freezing during playback or just sitting there not starting up properly?
by the way, would have been useful and get more people who might know the answer if you'd mentioned Netflix in the thread title
Re: Keep freezing
Good point, cant seem to edit.  It's freezing whilst watching it, first the sound goes and then it freezes.
Re: Keep freezing
Wonder if related to the pixelation problems people are having at the moment. Might be worth a call to sky to see if a box replacement is possible as some have had success with that. You'd lose all your recordings of course.
Re: Keep freezing
Sorry, more information I failed to detail...it's sky stream through a sky puck. I will phone sky when I get  spare hour in my life 😃
Re: Keep freezing
Ah - this is the Q forum. Maybe a mod can move this to the Stream forum.
