Discussion topic: Best way to connect to vga projector input
Message posted on 16 Mar 2025 01:35 PM
Hi. Can anybody help me with what is the best way to connect my sky q multi room box to the VGA input on my projector. Thanks
Message posted on 16 Mar 2025 03:53 PM
Re: Best way to connect to vga projector input
Message posted on 16 Mar 2025 03:56 PM - last edited: 16 Mar 2025 04:27 PM
Note that VGA itself won't carry audio.
Message posted on 16 Mar 2025 04:13 PM
Hi can you suggest one. As I've tried 3 and none seem to work. 2 active and one passive.
Message posted on 16 Mar 2025 04:21 PM
@Craigg73 wrote:Hi can you suggest one. As I've tried 3 and none seem to work. 2 active and one passive.
B0DRL4KFDZ
Message posted on 16 Mar 2025 04:28 PM
Is this one that you know will work? Thanks.
Message posted on 16 Mar 2025 04:51 PM
@Craigg73 wrote:Is this one that you know will work? Thanks.
Based on five stars and only one review I would try it myself if it didn't work I'd return it and order something else
Or maybe I'd upgrade my projector?
