Discussion topic: No satellite signal
This message was authored by: Clive40
No satellite signal
Sky broadband good but no satellite tv
Re: No satellite signal
@Clive40
If you’re seeing a “no satellite signal” message (as your thread title suggests) check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
