4
This discussion topic has been answered Discussion topic: Battery cover loose
This message was authored by: Tuft1
Battery cover loose
Sky Q remote cover loose and slips down!
Avatar for Tuft1
This message was authored by: Tuft1 Answer
Re: Battery cover loose
hi just to say thanks again just an addition to my post there is no charge. It is free which is marvellous. Thank you.
hi @Tuft1
I think the remotes are prone to this.
Personally I just suggest using some tape (black insulation tape may be better than sellotape) to hold it in place
@Tuft1
I've had 3x Sky Q remotes for 6 years and they are fine so are quite sturdy.
If you follow this link it should eventually send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
Failing that the quickest option is some sellotape on it.
Avatar for Tuft1
Thanks, followed the links and a new one is coming soon.
it was just the looseness of the the battery cover which was annoying me!
Avatar for Tuft1
